![]() | Home > Maintenance & Modifications > Rear Forward facing seat base size problem |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6654 ![]() ![]() ![]() |
I fear your seats squabs have been shortened, there shouldn't be rivets and glue on the bottom panel
![]() If you measure the length of the bottom squab from the backrest to the forward edge I can measure my seat to compare. ![]() ![]() |
mattcoll Member Since: 25 Jan 2025 Location: Norwich Posts: 3 ![]() ![]() ![]() |
I see, that's a shame
![]() Made a decent job of it though, everything is shortened, the glue and rivets look factory. Why would someone go to the bother?! Thanks for the offer to measure your foam bases Martin ![]() Click image to enlarge ![]() Click image to enlarge Last edited by mattcoll on 25th Jan 2025 11:08pm. Edited 1 time in total |
![]() Click image to enlarge ![]() Click image to enlarge Just nipped out to take these. ![]() ![]() |
Thanks again, yeah looks like I have some cut n shut seats. Everything is around 8cm shorter in the squab. Could shorten the lower frame and just go with it , or bite the bullet and get another set
