![]() | Home > Puma (Tdci) > Hi / Low range wiring |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1851 ![]() ![]() ![]() |
Can anyone shed some light on wiring colours please?
The wiring diagram shows and my 110 has a black and white wire to the Hi/Lo switch. Due to some cack handedness on my part I've managed to pull the connector off the flying leads to the switch (where it is attached to the transfer box bracket), these are coloured light green / yellow and dark green / black. There is no trace of insulation left in the plug to know which one goes to white, which to black - does anyone know please? Cheers Keith |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 205 ![]() ![]() ![]() |
I took photos of both. I don’t think matters as I think the switches are isolated and the ground external.
![]() Click image to enlarge ![]() Click image to enlarge |
You, Sir, are a gentleman and a scholar!
I will reconnect them tomorrow, still not sure how I managed to pull the plug off the end! Keith |
