Home > Puma (Tdci) > standing still
Caterham
standing still
looking for thoughts and opinions.
I've now got the defender sat outside after it spent the last 2 or 3 years sat indoors mostly on a c-tek.
I don't really have the luxury of using a c-tek at the moment (and besides I've just had to change my battery so I'm not convinced the c-tek extends the battery life?).
any hows I'm just wondering - if I run the engine each week for say 10mins would that be a good move alround ie for the engine and the battery. and perhaps drive back and forth 10 meters just to keep everything moving?
would 10 mins each week be sufficient to top the battery up and keep it it in good order?
Post #1057133 12th Jan 2025 12:59pm
landy andy
If you choose to start the engine, it needs to be started and driven. Not just started, and ideally need to be driven for long enough to get up to full temperature. Just starting an engine and leaving it ticking over isn’t good for it. Especially if you have an emissions stuff on it.
Post #1057137 12th Jan 2025 1:09pm
Caterham
Would you suggest even without the emissions stuff it would be a bad idea?
Just thinking about back up diesel generators - they get run regularly but obviously don't go anywhere and it doesn't seem to be a problem?
Post #1057143 12th Jan 2025 1:29pm
landy andy
Still a bad idea. The best thing for the engine, is if started, is to be worked and got up to temperature. A generator isn’t just running, it is driving the generator, so is working.
If you start it, work it. Otherwise don’t start it.
Is the basic message.
The best thing for a vehicle complete, is to be used on a regular basis. Something like an hours drive every two weeks or so. I know not always possible, as know personally with my camper, which is often just stood.
Post #1057157 12th Jan 2025 3:27pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
I'll echo the above if you're going to run the engine then it's got to be driven and got up to temperature properly.
I would say a good hours drive every fortnight would not only keep the battery good it'll keep the brakes clean and the oils / seals happy and moved about.
For outside infrequent used vehicles I recommend a solar trickle charger
https://shop.ringautomotive.com/battery-care/solar-chargers.html
Other brands available of course. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1057161 12th Jan 2025 3:45pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
You could also fit a battery cut off switch.
Post #1057163 12th Jan 2025 4:02pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Agreed with the above. Can’t remember if yours is a 2.2 or a 2.4 (ie DPF vs non-DPF) but either way cold starting and idling with no long runs/high load application causes all sorts of issues - cold engines have a lot of condensation, which mixes with the soot to form a sticky sludge and foul up the EGR circuit and DOC, if it’s a 2.2 with a DPF then adds a lot of soot load with no chance to burn it off.
Battery isolator or disconnecting battery negative is an option, or even buying a new battery when you’re ready to have it back on the road is less of a cost than the problems that idling for 10 mins every week could cause. Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #1057165 12th Jan 2025 4:19pm
TexasRover
Agree with budgeting for a new battery when time comes. I have had several vehicles sit (indoors) some batteries survive a recharge others don't. I disconnected, but on trickle chargers etc, but batteries just age over time and they are not all that expensive yet critical to enjoy your car.
You have to have a resurrection budget including bunch of fluids and possibly even tires and hoses ,(rubber)
Post #1057184 12th Jan 2025 7:15pm
Likeomg
We still have our 90 that's done 1 mile since delivery. gets serviced every year with no dramas. (yes a puma we trailered home, goes for service on a trailer every year)
Don't start it other than it going for its service, god knows about the DPF lives in a climate controlled environment the rest of the time until we decide what we are going to do with it.
Post #1057203 12th Jan 2025 11:53pm
Ianh
I have a picture in my mind of a pristine 90, sitting in a warm air conditioned glass garage , looking out over open countryside, with tears rolling down from its headlights. Rolling with laughter
Post #1057207 13th Jan 2025 12:15am
Likeomg
Well it’s never been washed, no chance yet for the rust marks from the headlamp bezels yet…
Post #1057211 13th Jan 2025 12:55am
Ianh
Thumbs Up Rolling with laughter
Post #1057215 13th Jan 2025 3:42am
lightning
Why would you buy a new Defender and just trailer it to a garage every year for a service without ever driving it.
ls it for an investment/pension ?
To be honest if it's never driven at all and kept in heated storage you'd be better just to drain the fluids, remove the battery and not waste hundreds of pounds on servicing, used oil disposal etc.
Post #1058648 26th Jan 2025 2:23pm
Caterham
thank you for the replies.
seems like I won't be running it then Mr. Green
already bought the new battery so I'll have to see how that goes. Thumbs Up
Post #1058895 29th Jan 2025 5:16pm
