![]() | Home > Maintenance & Modifications > is something wrong or is it me??? |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 681 ![]() ![]() |
I'd start by getting it jacked up ad go round the wheels and various suspension parts with a pry bar to see if it has any play on the various joints .. does it have anti roll bars ?
Check the prop shafts and diff slack ans see if you think its excessive.. Does the engine running smoothly ? I know you said it passed its mot but that's where I'd start.👍 |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2231 ![]() ![]() |
Have a look at your front axle, in particular the nearside welds, are there any cracks, is there any loss of oil, does your axle full within the recall range.
See https://www.defender2.net/forum/topic33029...;start=510 |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1847 ![]() ![]() ![]() |
Check axle first as above - my best guess would be panhard rod bushes but if you treated it to a full set of bushes & a decent set of shocks etc it would feel better than new again!
HTH Keith |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2660 ![]() ![]() ![]() |
Mine turned out to be the swivel pins.
It’s worth speaking to your local independent otherwise you could end up chasing your tail and spending money ‘on the off chance’. At the same time I also got them to fit the Gwyn Lewis steering kit. Good luck |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20706 ![]() ![]() |
Have you noticed it more since it’s been really cold? If so, with the cold especially under about 5.C all the rubber bushes get a bit more harder, so can feel a bit more different.
All you can really do is look for play in the bushes, I find rear damper ones are quite a common nuisance, steering component ball joints, steering damper etc is worth looking at. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Check the A frame ball joint, that can cause quite a wobble. It sits on top of the rear axle.
