Home > Maintenance & Modifications > wheel bearing maintenance and brake pads change
Eduardo
Hi there!
The 40,000 km maintenance includes a wheel bearing maintenance (grease and checking) and change the brake pads in the four wheels
I receive the invoice some days ago (not paid yet until all the clutch problems were cleared)
They are charging me 8 hours of labour for all this work. I found that quite excesive.
Works includes according to the detail
Greasing the bearing
Dismount the wheel hubs
hub maintenance
Change brake pads
Time for each labour were not provided
Any tought about the time to do this work?
Thanks ! Eduardo
Post #7508 18th Feb 2009 7:06pm
jhnharvy773@gmail.com
United States 2006 Defender 110 V8 Petrol PU Santorini Black
Re: wheel bearing maintenance and brake pads change
Eduardo wrote:
Hi there!
The 40,000 km maintenance includes a wheel bearings maintenance (grease and checking) and change the brake pads in the four wheels
hub maintenance
Change brake pads
Thanks !
I need to replace my wheel bearings on my 06 Jeep Liberty, i have found a site that sells them the cheapest, i wanted to know if it is simple straight forward or if i will require a hub puller? let me know how difficult this is going to be???
Thanks
Post #61149 26th Feb 2011 2:30am
AndrewS
Does an 06 Jeep Liberty have the same bearings as a Defender? 130's have feeling's as well you know Smile
Post #61151 26th Feb 2011 3:07am
110SEB
Oooooowwwwww my eyes! My eyes are burning! Someone typed the "J" word.
Whistle (just teasing jhnharvey! (Or am I?))
2 hours per wheel does seem excessive, but I don't know. Someone will know. Perhaps they are trying to charge you for a full day's labour for the whole service plus the bearings etc?
Post #61155 26th Feb 2011 6:49am
MK
One hour each wheel. Done it. 57 mm spanner tube (ebay, paddocks, etc). Grease, gasket and torque wrench.
Internal axle seals in case.
Anyway if you have not been wadding you could waint until 80000 km. Mine look just fine. Puma 110" SW
Post #61163 26th Feb 2011 8:34am
