Home > Puma (Tdci) > 3 Amigos - Potential Solution
Rossco123
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Caledonian Blue
Hi - I have been suffering intermittant 3 Amigos (TC, ABS and Handbrake Light) fault for the last 3 months - I spent a while researching and fiddling to see if I could solve - including checking all the wheel sensors.
I eventually scanned the car and it was showing an ABS Earth fault.
I cleaned 3 of the earth straps:
1) one behind the coolant resevior (under the bonnet) - this is where the ABS module is earthed to
2) one behind the drivers side front wheel (in the wheel arch) - i undid the bolt and cleaned it up using some wire wool/sand paper.
3) one bolted to the chassis under the car (directly below the passenger front seat) again using wire wool/sandpaper.
This solved the problem for me - a quick 30 mins fix....
Post #1055941 30th Dec 2024 6:43pm
Ianh
Thanks for posting Rossco, Thumbs Up
Post #1055955 30th Dec 2024 10:20pm
