Home > Puma (Tdci) > P228C
henlamb
New Zealand 2013 Defender 110 Puma 2.2 SW Orkney Grey
P228C
Hey Guys
Need some advice regarding P228C fault code.
Fuel low pressure. Lift pump in the tank doesn’t run whilst ignition is on.
Is it as simple as just replacing the pump or is something else at play here?
Thanks
Henry
Post #1055676 27th Dec 2024 6:38am
BrickBox
Assuming you have a 2.2 Puma, if you are mentioning a pump? 2008 2.4 110 Utility Station Wagon XS.
Post #1055678 27th Dec 2024 7:31am
andy63
First thing to do is check the fuse and relay that will power the tank pump when the ignition is switched..
It does only run for a bout 10 seconds..I assume there is a mechanical pump on the back of the high pressure pump that then does the job, but it's something I'm currently trying to find out a bit more about..ie intending to scope the low pressure line and monitor pump current..Just to see what is normal on the 2.2l engine..
My issue is finding a connector to fit to the bleed point under the green cap on the supply line to the pump..that's where I'm hoping to connect the pressure transducer..
I digress🤣...
With your tank pump not running starting with fuse and relay ...but I'd have thought it should still running once started in spite of that..
May be a vcv valve issue as well..
Post #1055680 27th Dec 2024 7:37am
andy63
Should really have said start with a correct wiring dig and identify the fuse and relay👍🤣
Post #1055681 27th Dec 2024 8:03am
andy63
You will have to excuse me.. my heads not working to well this morning..
Another point is when was the fuel filter last changed..
I'll get all me points out eventually..
Sorry🫣🤣
Post #1055683 27th Dec 2024 8:16am
henlamb
Fuse and relay are fine, I’ll jump the fuse to send 12v to the pump to see if I can drive it into action. Otherwise it maybe the CVC which is faulty?? Bit of a loss here as away from home and it’s the holidays and nothing is open 😅
Post #1055687 27th Dec 2024 8:58am
andy63
And the filter would be an issue if its been neglected..
Hope it sorted easily..
Post #1055689 27th Dec 2024 9:13am
Ianh
Worth checking the inertia switch and the fuse (fuse 9 5Amp ) that serves it.
Post #1055707 27th Dec 2024 12:47pm
andy63
If the inertia switch was actuated then the engine wouldn't start.... the injectors would be disabled as well as the tank pump...I had presumed that wasn't the case.. have I got that wrong🤔😫
Post #1055708 27th Dec 2024 12:50pm
Ianh
I suspect you assumed correctly Andy , and the engine is running and therefore not the inertia switch. However as the OP has not stated whether the engine was running or not, and it’s a 5 min job to see if the fuse is ok and to check continuity of the switch then it’s worth a quick look if engine not starting.
Post #1055712 27th Dec 2024 1:27pm
andy63
Thumbs Up definitely
Post #1055714 27th Dec 2024 1:37pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Test the fuse in situ with a test light. Do not jump the fuse. If it popped, it did so for a reason. You don’t want to burn up your wiring or worse.
Post #1055716 27th Dec 2024 2:00pm
henlamb
So power is getting to the pump after all. So just need to source a new pump
Post #1055759 27th Dec 2024 11:57pm
