Home > Off Topic > formwork for concrete |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1795 |
Hopefully someone can enlighten me!
Current project is a small pool that is semi in the ground, and will be in an insulated brick building when finished. There is a walkway down one side about a meter wide against the bi folds and an area across the bottom where there will be a little sitting area and a room with a shower etc. -a L with a fat bottom! Under this will be the pump room, all walls are reinforced concrete lost formwork so I need to cast a concrete floor. Can I use polythene sheet over the ply & timber shuttering instead of the specialist oils / DIY diesel to release the wood when done? Cheers Keith |
15th Dec 2024 6:16pm |
