![]() | Home > P400e Area (L663) > Camping and using sockets on defender P400e |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2767 ![]() ![]() |
Do you mean the 12v cigarette lighter socket or do you have the 230V 3 pin socket too?
Either way though, they will only be powered up when the ignition is on so you won’t be able to leave a fridge running when you’re away from the car, or for long periods. The P400e will ‘shut down’ after a long time powered up if you don’t drive or press the brake pedal so it helps a bit but not loads. If you want to run a fridge continuously then a battery pack (EcoFlow / Jackery etc) is a good option short of installing a second battery Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Elbek Member Since: 14 Dec 2024 Location: Uzbekistan Posts: 9 ![]() ![]() |
Both sockets actually. Just wondering if I leave like 50 percent of my battery and will turn on lights, open doors, using sockets without actually driving the vehicle(running ICE) for a two days, will it drain the 12v battery? Or the phev battery charges 12v, and I should not worry?
Yeah the HV battery will keep the 12v battery topped up 👍
Sockets etc don’t stay on for very long though without the car “running” so you’ll find yourself turning the ignition on a lot if you want to draw power Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Thanks for the reply!
