![]() | Home > Puma (Tdci) > How does the fan blower intake attach to the blower housing? |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
AFAIK that's as designed.
I fabricated my own fixing method here, providing a better seal that reduces engine noise in the cabin and helps a bit with the A/C in the summer. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17623 ![]() ![]() ![]() |
It's been discussed on here before, many people's vehicle had had gaps between the parts large enough to stick your hand in. Some have double up on the foam "seal" or taken other steps to improve the fit. It also seems to be very variable from one vehicle to another.
It is certainly not Landrover's finest pinnacle of design brilliance. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2170 ![]() ![]() |
This is worth a read on the subject, with a couple of solutions.
https://www.defender2.net/forum/topic75787.html?highlight=heater |
Defender_work101 Member Since: 30 Nov 2024 Location: Scotland Posts: 8 ![]() ![]() ![]() |
All good information here guys. This issue is obviously a design flaw which unfortunately has dire consequences to our health and preservation of our vehicles. The smoke and diesel exhaust fumes are easily sucked inside the vehicles if the surfaces between the blower housing and intake housing aren’t pulled/sealed together. Obviously any engine “blow by” smoke or slight exhaust leaks will be sucked directly inside the cab which is not only unpleasant but very unhealthy. This is true even if these surfaces are sealed tight, but more so than being pulled in from outside the wing top. Water ingress into the heater blower housing/cab is also a major issue, not only causing eventual failure of the blower motor and resistor but also water ingress inside the vehicle will result in corrosion of firewall/floor boards and fasteners.
I’m attempting to figure out a resolution, either with rivnuts/stainless safety wire or plastic wire tie cables/anchors similarly accomplished by a previous member. I considered using stainless boot spring latches which would encompass drilling into both housings but would ensure a steady and constant “pull” I will keep you informed and attempt a fix once it warms up a little. |
Except that there should be no exhaust fumes round the engine unless the exhaust is leaking, and any blow-by gasses should be ingested by the induction system from the crank case breather.
If you're getting either in the cab it's probably worth fixing that problem as well as the poorly-fittng heater trunking. |
![]() Click image to enlarge Here’s my solution for the poor fitting air intake cowl to heater blower fan housing. I purchased a small “pump air wedge” off eBay, they’re typically used for lifting and aligning objects during construction or levelling of furniture etc. They’re also available at Screwfix and other retail stores, they’re cheap and made from heavy duty vinyl. If you’re unfamiliar with these I will include an image, it took less than a minute to install and super easy. Slide the small flat bag between the air intake cowl and the inner wheel liner and pump the bulb a few times just enough to lift and push the intake cowl towards the heater blower housing, and done. It is easy to control how much force/pressure you use by adding or reducing air through the bulb. I will be periodically checking pressure but just in case the bag deflates I’ve used a small zip tie to loosely hold the bulb to the harness for the fan blower. No more water entering the blower housing and no more outside odors pulled through the fan housing into the cabin. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3351 ![]() ![]() ![]() |
It’s not a design feature? I always thought it was a quite effective coolant leak detection sniffometer. WARNING. This post may contain sarcasm. |
