![]() | Home > Td5 > TD5 starting problems ? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5813 ![]() ![]() |
Check you get pump noise each time before you attempt a start. If you are not getting any pump noise. Wiggle the relays.
Another thing to check is to clean the crank sensor. These can get mucky and cause issues. It’s in the bell housing by brake servo/air filter box. |
TaylorTD5 Member Since: 21 Oct 2023 Location: Winchester Posts: 3 ![]() ![]() ![]() |
I have checked that the relay clicks each time I switch on the ignition which seems to be operating ok. I will check the crank sensor and clean up the terminals etc
Thanks |
The crank sensor needs to be removed for cleaning. Bit fiddly, but simple 👍🏻👍🏻
Great I remove it and give it a clean up👍
