![]() | Home > In Car Electronics > Headlight level motor fuse 13 |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 854 ![]() ![]() ![]() |
Hi
Is the other symbol the one for the in instrument binnacle illumination? You should add the details of your vehicle to your profile so that folk can see the year and model of your Defender. Jim |
xrodney Member Since: 09 Jun 2024 Location: Malta Posts: 13 ![]() ![]() ![]() |
It is a 2015 2.2 puma. Instrument binnacle lights up
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5820 ![]() ![]() |
The symbol looks more like a rev counter as has the slope under it.
Or possibly for the unit which increases revs for PTO (when/if fitted) Or tacho (when/if fitted). |
Rev coumter works too
Must be another accessory Defender 110 Utility Station Wagon 2015 2.2 Puma |
As long as everything works I’m sure it will be fine. Just carry the fuse in case.
Alternatively disconnect the levelling motor. My headlight levelling motor is the opposite to yours. After a bird strike it now longer works. ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6643 ![]() ![]() ![]() |
None of your dash switches will be illuminated with F13 removed.
The icon means dash/gauges illumination, however the icon is misleading, as the cluster is actually illuminated by the sidelight feed it receives from F11. https://www.lrworkshop.com/wiring-diagram/...lumination ![]() ![]() |
I still have illumination in switches Defender 110 Utility Station Wagon 2015 2.2 Puma
Solved. Yes Martin there was no illumination on the centre switches.
Took out the headlight, loosed the bolts and all is working Defender 110 Utility Station Wagon 2015 2.2 Puma |
