![]() | Home > Maintenance & Modifications > Confirm mobil oil which one |
Landy49 Member Since: 29 Feb 2024 Location: Hampshire Posts: 53 ![]() ![]() |
Hoping someone can clarify for me which mobil oil is the correct one for my 2016 2.2
Is it either Mobil Super 3000 Formula R Engine Oil - 5W-30 https://www.eurocarparts.com/p/mobil-super...-521779241 Or Mobil 1™ ESP Formula P 5W-30 https://www.eurocarparts.com/search/521779661 |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2240 ![]() ![]() |
Look at the spec sheet for the oil.
With a 2.2 you will have a DPF which means the oil needs to be low SAPS (C1) and meet ford spec WSS-M2C-934-B. See https://www.defender2.net/forum/topic34176.html which shows Mobil Super 3000 Formula C1 meets the spec. |
Many thanks my confusion was the c1 part!
Thanks sourced some from CMG OILS DIRECT
