Home > Puma (Tdci) > Blowing oil filter o-ring / seal
110pete
Northern Ireland 2010 Defender 110 Puma 2.4 DCPU Java Black (black Hood)
Hey there, I’ve had the o-ring on my oil filter fail twice now.
First time it happened I had just pulled out of my yard when I head the oil being dumped on the ground. Pulled back into see the oil dripping from the engine and feared the worst.
On inspection I thought the seal had just failed, everything looked fine with the filter housing etc and nothing externally on the engine looks out of place or was causing any concern.
So, I picked up a new filter and oil and went about fitting it and refilling with oil.
Car started fine, no leaks. Let it idle for 5-10 mins with no issue.
Reached in with my hand and touched the accelerator pedal, as soon as I did it blew the seal on the new oil filter. Dumping the new oil on the ground Crying or Very sad
I’ve since dropped the sump off to check the pick up pipe (was wondering if there was a blockage somewhere causing the seal to go) and it seems to be not too bad.
Does anyone know if there is a pressure release valve on these oil pumps?
It’s a 2010 2.4.
Thanks in advance for any help.
Post #1051846 15th Nov 2024 3:36pm
landy andy
Definitely got the old seal off? Only seen this when two seals were on filter head.
Post #1051853 15th Nov 2024 4:55pm
The relief valve is integral to the pump. This from the 2.4 genuine LR WSM:
The Land-Rover workshop manual wrote:
Lubrication System Operation
Oil is drawn, via a strainer and pick-up pipe in the sump into oil pump, which has an integral pressure relief valve. The strainer in the pick-up pipe prevents any ingress of foreign particles from passing through to the inlet side of the oil pump and damaging the oil pump and restricting oil drillings. The oil pressure relief valve in the oil pump opens if the oil pressure becomes excessive and diverts oil back around the pump.
The lubrication system is designed so that a higher proportion of oil flow is directed to the cylinder block main oil gallery while a lower proportion of oil flow, (controlled by a restrictor in the oil filter housing), is directed to the engine oil cooler. The remainder of the oil flow from the outlet side of the oil filter is combined with the return flow from the oil cooler before being passed into the cylinder block main oil gallery.
The main oil gallery has drillings that direct the oil to the cylinder head and the main bearings. Cross drillings in the crankshaft main bearings carry the oil to the connecting rod big-end bearings. Oil galleries in the cylinder head carry the oil to the camshafts and the hydraulic lash adjusters.
The oil pressure switch is located in the oil filter and oil cooler mounting plate to sense the oil pressure level before the oil flow enters the main gallery in the cylinder block. A warning lamp in the instrument cluster is illuminated if low oil pressure is detected.
Oil at reduced pressure is directed towards the cylinder head via a restrictor in the cylinder block/cylinder head locating dowel. Oil then passes through a drilling in the cylinder head to the camshaft carrier, where it is directed via separate galleries to the camshaft bearings and hydraulic tappet housings. Return oil from the cylinder head drains into the sump via the cylinder head bolt passages.
Post #1051854 15th Nov 2024 4:56pm
110pete
Thank you for the info.
I’ll check the pump tomorrow 👍👍
Post #1051866 15th Nov 2024 10:20pm
