![]() | Home > Technical > 110 rear light issues |
86110Utility Member Since: 15 Apr 2021 Location: Shropshire Posts: 7 ![]() ![]() |
Hi all, I’ve got a new issue with my 110; a few weeks ago I noticed that while the brake light is working fine, the near side rear side light and licence plate light are out until I plug my trailer in then they work fine - what do I need to look at (wiring loom is a total mess (from when I bought the LR) and the trailer is a Penman which I converted to 7-pin 12v electric's).
Any & all help appreciated Cheers 🍻 |
Thanks Mark - yes the front end of the loom is worse and I’m also having issues with front headlights & spots too but that’s for another days fix lol !
I’ve fitted new LED rear lights over a year ago and just Monday fitted a new LED license plate light (as oem was badly corroded and had stopped working as noted above) so will pull the rear wiring/loom out and check it for wear, chaffing, etc. and hopefully find the issue. |
