Home > Technical > Central Locking Circuit pulling current
Gareth356
United Kingdom 2014 Defender 110 2.5 TD SW Firenze Red
Hi All,
First time post so be gentle! I've tried searching but not found anything exactly matching.
My '14 Defender has been flattening the battery, I've isolated this to the central locking fuse 20A under the steering column. When I lock the vehicle with the fob, all the locks work normally (possible exception that sometimes the back door intermittently) but there is a following 'whirring' type noise afterwards. Before I start replacing things, has anyone had similar? Could it be a short with the wiring (I've seen some of those) but then the lock appears to bot work at all?
TIA
Post #1051332 11th Nov 2024 3:41pm
