![]() | Home > Td5 > Left wing top removal |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1152 ![]() ![]() ![]() |
Although there are three pieces (top front and side) only the side is removable. The top and front are rivited together, so yes removable but only with a bunch of effort. (There is the inner plate too actually)
The whole wing is fairly easy to remove and you can buy complete replacements. If you don't mind the chequer rash surely you could hammer the top plate up a little before fitting your chequer plate? |
Scottyboy Member Since: 09 Jul 2024 Location: Kaiserslautern Posts: 10 ![]() ![]() ![]() |
Thanks for your reply. I will give it a try.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 961 ![]() ![]() ![]() |
If you don’t like diamond plate wing tops, look for smooth aluminum plates. Much easier on your elbows and knees.
![]() Good luck ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
That does look nice.
