Home > Puma (Tdci) > Fuel rail temperature Puma 2.4 or 2.2
MK
Gents
May I know what sort of fuel rail temperatures are you reading on a 2.4 (a 2.2 should be around the same) with a hot engine? I suspect I have a faulty sensor.
Thanks in advance. Puma 110" SW
Post #1050891 6th Nov 2024 12:05pm
MK
I think I found it. Nanocom readings are wrong. Puma 110" SW
Post #1050909 6th Nov 2024 3:24pm
Julie
Did you update to the latest version 1.38 from sept 2024 ?
They corrected their faulty OBD readings since the DPF reset did not start (with their faulty oil temp read out)
Post #1051131 9th Nov 2024 7:58am
MK
Yes, I have the latest version. Not the first issue I found on the Ncom. 2.4 users may find that the engine temperature displayed at the pump learn menu is totally out of range. I had to show BBS two cases of this issue to then believe me. It took about 2 weeks for them to fix it. I cannot remember the date, but it was not long ago. Puma 110" SW
Post #1051155 9th Nov 2024 2:43pm
