Home > General & Technical (L663) > 4x4 Predator Side steps |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 91 |
Has anyone had dealing with these side steps?
https://www.4x4predator.co.uk/predator-4x4...2020-l663/ |
4th Nov 2024 12:12pm |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 215 |
Nope but I fitted the ones from www.sidesteps.co.uk and I'm extremely pleased with the quality and price. Way easier to fit than most other styles too.. MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
4th Nov 2024 12:51pm |
Thanks
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2906 |
They are exactly the same design as the LR OE ones so should fit perfectly. The only difference is, the steps are all black and are made from a type of plastic/resin where the LR are alloy. However l think the plastic may actually be better as the alloy steps can develop surface corrosion after a couple of years and while not structural makes them look tatty. The aftermarket steps are very strong and don't flex at all. l've had both on my 90. The main advantage of the Predator (or similar, l think the aftermarket suppliers are all selling the same parts) is they are about 1/4 the price of the LR part. |
4th Nov 2024 3:58pm |
Davedig Member Since: 18 Feb 2024 Location: England Posts: 26 |
Has anyone used the predator wheel spacers?
5th Nov 2024 6:49am |
Thank you |
5th Nov 2024 12:13pm |
