Home > Puma (Tdci) > LED lights and buzzing relay |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20466 |
Try adding a temporary additional ground, prior to that you can try a continuity check on that pin.
LED’s (and associated components) are sensitive to grounding issues or voltage fluctuations, so the ground is a likely possibility that it has a high continuity reading and is common. Also worth checking the rear grounds for the rear lighting loom on the transfer box. |
2nd Nov 2024 5:47pm |
Matt_3545 Member Since: 23 Sep 2024 Location: Stourbridge Posts: 3 |
I'm not great with electrics so sorry for the daft questions. Is it just a case of checking that the earth connections are secure correctly?
Also, is it easy enough to add an additional earth? How would I go about it? |
2nd Nov 2024 7:47pm |
grahamb31 Member Since: 14 Nov 2024 Location: Bo’ness Posts: 1 |
Hi, curious if you found a solution? I have the exact same problem. If I have heating hot it stops buzzing quicker.
14th Nov 2024 4:13pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
When the indicators are buzzing, try switching the hazards on and off a few times to see if it changes. The indicator relay is fed through contacts on the hazard light switch that in my case caused extra resistance which was just enough to start the relay chattering (buzzing). If it changes the buzzing then the hazard light switch is the culprit.
I found that - temporarily - switching the hazards on and off again a few times cleaned the contacts. But a replacement switch solved the problem completely. Dave Green Goddess - 1998 Defender 110 300tdi |
14th Nov 2024 6:19pm |
SuperDMan Member Since: 17 Nov 2024 Location: Germany Posts: 3 |
Also curios if you’ve found solution. I’m having the same issue!
17th Nov 2024 11:44am |
Hedwig Member Since: 20 Feb 2022 Location: Midlands Posts: 40 |
Recently swapped all indicators to LED and had a buzzing noise on the relay. Bizarrely this was only the case when the engine was running, if done on ignition it was the normal tick noise. Referred this back to the supplier of the lights kit, Wipac sent a new relay and the problem was resolved.
18th Nov 2024 12:20pm |
Hi mate, sorry I thought I'd replied to this but it obviously didn't get sent for some reason. Hopefully you've fixed your indicator flashing issue but if not then this is what I did. In the end I got rid of the wipac/Bolt on Bits flasher relays and put the OEM one back in then fitted resistors to each of the indicators, which has fixed the problem. This is the link to the resistors I used: https://www.ebay.co.uk/itm/384097170883?mk...media=COPY |
30th Dec 2024 8:14am |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 120 |
If you fit LED turn signals then you need to fit an LED flasher relay.
1st Jan 2025 5:47pm |
