Where did yo7 get the side fuel can and bracket that goes under the ladder?
28th Oct 2024 10:43pm
Will.I.AM
Flatdog do an excellent roof rack for the L663 110 and they also do roof tent brackets which i have used for my tentbox which make access to the nuts and bolts easy - also although in theory there's nothing wrong with tentbox's proposed method of clamping under the roof bar, it is not a great method and you do hear the occasional horror story of them coming loose and coming off.
With it bolted tight and flat down to a metal bracket, with no flex in the bent metal straps underneath, it is a belt and braces fixture - in my opinion which may of course not be correct!
