![]() | Home > Technical > P061B ERROR CDE |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2234 ![]() ![]() |
Here is some insight into the code and it’s potential causes, https://www.kbb.com/obd-ii/p061b/
It could be many things , but given you have a non std map I would suspect that first. If the check engine light went off by itself then it’s because the ECU has run the same tests that triggered the DTC and the engine has subsequently passed those tests several times. This is probably because you have not put the engine under the same stress as you did when the DTC was generated. However if you do again I suspect the same issue will occur. |
iamdimitris Member Since: 03 Oct 2018 Location: Limassol Posts: 43 ![]() ![]() ![]() |
Hi Ian,
thanks for for you answer - the link gives me access denied. Would you happen to know if ther's any way to know what mapping is on my ecu? It was done from the previous previous owner and no way to get that info directly 2013 110 XS SW 1971 Series 2A LWB 2007 DCPU 2.4 (SOLD) 2015 DCPU 2.2 (SOLD) |
