Home > Off Topic > Ford Transit 2.2 can the DPF be blanked? |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 861 |
I didn’t think the 2.4 came with a DPF. Do you mean EGR blanked and mapped out? 2008 2.4 110 Utility Station Wagon XS.
22nd Oct 2024 9:55am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3471 |
As said, EGRs are blanked off (so no exhaust flow back into the intake).
DPFs are gutted out or deleted so the action, albeit illegal on road going cars, allows the exhaust to escape out more freely. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
22nd Oct 2024 10:01am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3790 |
Sorry your both correct the EGR was blanked off
22nd Oct 2024 10:19am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2109 |
If the 2.2 is having DPF issues you can MAP the DPF out, however it will also require the removal of the DPF, else it will block with soot. If you think about it the “Rest of world” Defender 2.2 spec without the DPF had a specific map from LR to run without a DPF.
Im sure there is a transit Map out their for a DPF delete, however remember the MOT requires a visual inspection to see if a DPF is fitted, so a good “Fake “ DPF will need to be fitted in place of the existing DPF. If you do go down the remove DPF and Map the DPF out route you can also go down the mapping out and blanking EGR route, something you can’t do if the DPF is present. See this other topic on blacking an EGR on a 2.2 with DPF.. https://www.defender2.net/forum/topic85834.html?highlight=dpf
With regard to the transit DPF getting blocked. There may be a fault with the DPF differential pressure sensor, the pipes from the sensor to the DPF, the electrical connector to it, or it’s wiring. The Glow plugs also play a role in regeneration so if he has a poor performing or dead glow plug this can prevent active regens and cause the DPF to block. First thing I would test is glow plug resistance. So what DTC’s is he getting ? Ps. If the transit is only doing short low speed journeys it will block, it needs to go on a 30plus minute 60plus MPH journey once or twice every 2 weeks. |
22nd Oct 2024 11:04am |
