![]() | Home > Maintenance & Modifications > Window guide - How to? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3520 ![]() ![]() ![]() |
Bit of a job to replace. The sequence to do it is:
1. Remove winder and glass 2. Remove the window channel on the hinge side of the door 3. Remove plastic trim 4. Remove remnants of the old guide Refitting: 5. Fit the new guide on the door 6. Fit the plastic trim 7. Fit the window channel 8. Refit the glass and winder I hope I got the sequence right, but recall that the the guide is the last to come out and first to fit. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2145 ![]() ![]() ![]() |
It’s really quite a faff. I’d only do it if I were replacing all the plastic guides, channel, felt, seals etc.
When I replaced my doors, I did the whole lot and right at the end of the job that sodding thing snapped off. Fit wind deflectors - it’s easier, does the same job, and more beneficial! |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 972 ![]() ![]() |
That clip goes in between the plastic trim and the felt channel. I have just redone all the trims and felt on my doors, I left this bit out (deliberately).
If you are lucky, you may be able to get away with taking the window all the way down, finding and removing the 2 self-tappers that are holding the felt channel in place and then pull the channel out from the top. This would give you access. It really depends on how stuck in the felt channel is ![]() |
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 177 ![]() ![]() ![]() |
Thanks all sounds like a right pain as I feared
![]() The window goes up when your stopped but if your on the move it catches the top so thinking the guide might be useful ![]() So I need to try and pull back the felt strip and locate 2 self tappers... if not it's a total strip down in essence ![]() Click image to enlarge |
The self tappers hold in the felt strip. So find and remove those first, then hope you can pull it out.
