Home > Faults & Fixes (L663) > L663, Information about the turbo.( UPDATE) |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 205 |
I see a small residue, perhaps the origin of the previous one pushed by the wind from the fan? Coming out of this small rubber tube that connects this register with a kind of sensor... Can someone give me a clue as to what the hell that sensor is? It's very few kilometers for the love of God... I don't want to think about when this is 18 years old and 400,000 like my beloved D3.
Click image to enlarge Click image to enlarge Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
22nd Oct 2024 9:48pm |
eno Member Since: 15 Apr 2024 Location: Qld Posts: 30 |
It is not easy to tell from the pictures but could it be thread sealant for the fittings?
Can you wipe the pieces clean and see if it comes back? |
23rd Oct 2024 8:41pm |
I will try, thanks ENO for your kind reply!!👍🏼 Defender 110 SE I6 D250 23MY
23rd Oct 2024 8:54pm |
o-ren-ishii Member Since: 25 Jul 2023 Location: The Hague Posts: 35 |
You can find/but the workplace manual online. Id say this should be described in there.
24th Oct 2024 7:29am |
Hi, please, do you know any links?thnks!! Defender 110 SE I6 D250 23MY
24th Oct 2024 7:32am |
I send you pm
24th Oct 2024 7:37am |
thanks very much buddy!! Defender 110 SE I6 D250 23MY
24th Oct 2024 8:30am |
update …It is premature, they have to do some tests, but the dealer is considering changing the turbo under warranty, well really are “the turbos” since there are 2 in cascade… I don’t know very well the scope and and neither the complexity of such an intervention…but I hope that, if at the end is necessary, it is a good decision and that they are at a sufficient technical level… I am a bit scared in a car so new! scary days!! Defender 110 SE I6 D250 23MY
28th Oct 2024 10:55pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2848 |
Mine has always had a very small leak from that joint. l've looked at three others and they all had the same trace of oil from there.
l've never done anything about it, l think allowing the dealer to take it apart will generate more issues. |
29th Oct 2024 7:52am |
That is very valuable information, meaning that they could put in a new turbo, with the risk that this entails, and the same thing would still happen… it makes me think then, thank you very much for your contribution.👍🏼👍🏼👍🏼👍🏼👍🏼 Defender 110 SE I6 D250 23MY
29th Oct 2024 8:18am |
If anyone else is willing to take a look at their turbos I would be very grateful!! very ver gratefull!! Defender 110 SE I6 D250 23MY
29th Oct 2024 8:21am |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 55 |
If I get around to it I may look at mine... D300 have the same turbos, right?
Also, on r/Newdefender I read that one of the two most common problems is something to do with the turbo cooling pipe (the other is DRLs manufactured during COVID) |
29th Oct 2024 10:17am |
I will be attentive! thank you very much! 👍🏼
The problem that the dealer poses is that the turbos are not dismantled, they are “simply” exchanged as a whole block…what a problem when the warranty is no longer available!! 🤬 Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
29th Oct 2024 11:00am |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1110 |
Hi A1C6 What is this about drl’s manufactured in covid? I am about to send my car in for a new headlight because of failed drl, and have been told it will be chargeable. 9 months out of warranty. If anyone has had a goodwill gesture it would be good to know. Cheers 👍 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
29th Oct 2024 9:29pm |
