Home > Puma (Tdci) > Rear Fog light
kmac
Rear Fog light
My rear fog light is not working Sad
So the bulb looks okay but the little green light on the momentary switch does not come on.
Checked all fuses and all are okay.
Any ideas - any way to test the switch itself?
Post #1047080 28th Sep 2024 10:41am
ak615
check the contacts in the bulb holder are pressing against the lamp ,I've had these get pushed back and not make a good connection in the past.
You can prove voltage at holder with a test lamp or multimeter.
Post #1047094 28th Sep 2024 1:10pm
kmac
Doesn't seem to be current at the switch end with engine on but all fuses seem okay (sight tested not multi-meter continuity tested)
Post #1047095 28th Sep 2024 1:12pm
TexasRover
Just a little something: does you fog light only work with the head lights on?
Post #1047096 28th Sep 2024 1:49pm
kmac
Good point - will need to check that out
@Texas Rover - you are a champ.
My fog light works fine - headlights need to be on.
Was only testing in preparation for an MOT, which passed in any case as they didn't check the fog light.
Post #1047104 28th Sep 2024 3:00pm
