![]() | Home > Puma (Tdci) > Stuck in First - need to get at detent |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8176 ![]() ![]() ![]() |
i took the hi low lever off - its a pain refitting lining up the bushes. and took the gear lever bottom mech out.
ali section can then come out with the plastic tunnel pretty much where it is. you can then get to the detent. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5820 ![]() ![]() |
