![]() | Home > Modifications & Maintenance (L663) > Oil change |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 240 ![]() ![]() |
Sucking method - does your pipe go into the dipstick tube or just over the top? On my 2011 4.4 tdv8 the Draper vacuum pump pipe fitted snugly over the top inch or so. MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1125 ![]() ![]() |
Yep! A lot of oil comes out very quickly!! I too ended up with a sleeve full of hot oil and missed the catcher.
Boiling water, a bottle of washing up liquid, scrub with a yard brush, and a blast with the washer cleans up the mess. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3015 ![]() ![]() |
On the D250 (diesel) the tube goes down the dipstick hole. |
Thanks lightning. I thought that was the case as per video below. Albeit a petrol.
?si=YLT2gUin7_SOrzuG MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
