Home > Puma (Tdci) > 2.4 Defender Battery
Naycrx
Good Morning
We left our defender for 2 weeks and had a flat battery- Boosted and has been fine since - left for just over a week and the same thing so i new battery will need to be fitted
Could anyone Tell me if there is anything i need to do regards fitting a new Battery? or just swap over?
Thanks
Post #1045276 9th Sep 2024 7:06am
andy63
Hi...I would check the current drain before deciding on replacing the battery..you wouldn't want it to be much above say 80ma as a ball park figure.. if excessive drain is the issue you will have the same problem with the new, and that's assuming the alternator is working properly
On mi 2.2 tdci I need to get the battery neg cable disconnected within about 15 seconds of switching off the ignition or the alarm unit sounds..
What I don't have to bother about is radio codes..
Post #1045277 9th Sep 2024 7:16am
Naycrx
ok will do - the last time we boosted it - it was stored at a classic garage - he believed one of the cells felt hot while charging - and so a new battery maybe required-
ok - ignition on and off and disconnect- it doesn't have an alarm only an immobiliser
battery wise any recommendations?
halfords have this one in stock
Yuasa HSB019 Silver 12V Car Battery 5 Year Guarantee
Post #1045280 9th Sep 2024 7:28am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
The battery is a good one and I can recommend it: I thought I needed to replace one myself recently, but my typical low-tech fix was to ram some lead scraps between the battery terminal and the awful Land Rover connection which wouldn't tighten enough (good enough connection to run the vehicle but on occasion when starting the connection failed and set off the alarm).
BUT, you can find it cheaper than Halfords price. Battery fitting a doddle, if I can do it ANYONE can...
Peter
Post #1045291 9th Sep 2024 9:24am
Naycrx
Morning,
thanks for the reply- yes i was just a bit worried about losing immobilizer settings and having to have them re coded etc....
i was able to Purchase a Bosch battery - the same ones thats on
Post #1045292 9th Sep 2024 9:46am
kmac
Good battery but unless you have a trade card, the Halfords prices are excessive.
Shop around, try Tayna for example.
Post #1045439 10th Sep 2024 4:10pm
I have that Yuasa battery too, it’s actually a slight upgrade to thr factory fit when I checked the specs.
Defender batteries typically last many, many years so it’s common there is a separate fault if there is any issues with drain, and a new battery won’t solve that. TheThunder Rolls🇬🇧🇺🇸
Post #1045445 10th Sep 2024 4:30pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Well after 16 yrs my battery has done its bit, just replaced with a Yuasa HSB019, purchased from Halfords bit pricey but it does the job Thumbs Up Cogito ergo sum
Post #1050014 28th Oct 2024 8:53am
Caterham
why is there apparently two different batteries (that are the same);
So, what is the difference between YBX5019 vs HSB019, here is the simple answer they are exactly the same,
Post #1050720 4th Nov 2024 2:18pm
