Home > Wheels & Tyres (L663) > Melting Back door tyre
GAT
I was wondering what might have happened to this tyre Shocked
Just removed the wheel cover and found the rear tyre has melted. Anybody else seen such a thing? I can’t see the sun has done this surely. I’m wondering if it’s been wiped over with some chemical substance which has had a dramatic reaction with it?
The bottom of the wheel isn’t as bad as the top.
 First Edition 90 in Pangea Green. (Gone)
P400 110 in Tasman Blue.
Post #1045120 7th Sep 2024 5:56pm
lightning
Wow that's something l've never seen before. How long has the tyre been on the back of the Defender?
Post #1045130 7th Sep 2024 7:20pm
GAT
I only picked the car up on Tuesday so can’t be 100% sure but the previous owner had the wheels refurbished black so I don’t think very long.
The car had previously been damaged so I’m wondering if the body shop had wiped the wheel to remove dust etc with a chemical or something which has reacted like this.
Certainly a strange one. First Edition 90 in Pangea Green. (Gone)
Post #1045132 7th Sep 2024 7:24pm
WizzardPrang
Maybe overheated in the body shop's paint oven? Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1045144 7th Sep 2024 9:05pm
Dinnu
Tyres are vulcanized at quite a temperature as part of the manufacturing process, which temperature is much higher than any paint oven would normally reach.
Given that the wear indicators do not show any melting, I do think that this is caused by a chemical process. Rubber is a derivative of oil, and breaks down when in contact with oil. Some oils will break it down faster than others. It could have been something as simple as driving at slow speed over a contaminated surface, like in a workshop.
The first picture shows what seems like water droplets between the thread pattern. Is that water? Or something oozing out of the rubber?
Other pictures show quite some rot as well. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1045160 8th Sep 2024 2:18am
taffy
Its got to be worth speaking to the manufacturer
Post #1045162 8th Sep 2024 3:06am
revd
Parked overnight in a puddle of oil/atf/brake fluid?
Probably never know
Just replace and move on
Post #1045167 8th Sep 2024 6:54am
H1Tad
United States
If it was in a paint shop, I'm more than willing to bet that some hamfisted paint prepper was standing on a stool and knocked his can of acetone over which spilled onto the tire. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package
2003 Hummer H1 P400 Firehouse Red
2008 Toyota FJ Cruiser
Post #1045211 8th Sep 2024 12:38pm
DFNDER
Australia
Yup, that's definitely caused by thinners or acetone. Shame they tried to hide it by just putting the cover back on.
Post #1047148 29th Sep 2024 1:59am
Grouse
They didn’t remove the tyre when the rim was refurbed and probably sprayed the whole wheel with paint prep degreaser prior to paint
Post #1047151 29th Sep 2024 3:33am
