![]() | Home > Technical > Throttle completely cuts out on 2006 Defender 90 TD5 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5813 ![]() ![]() |
It is a well know issue that the wires from the TPS to the ECU rub through and cause the symptoms you mention and is cured by running a new loom from underseat ECU to TPS, using trailer multicore cable.
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 222 ![]() ![]() ![]() |
I'd second this. I had very similar random issues which have all been solved by re-doing the wiring from ECU to pedal.
You can buy the replacement looms now too https://www.ebay.co.uk/itm/156366030041?mk...media=COPY 1990 Defender 110 200TDI Camper - now converted to Td5 power |
