Home > Puma (Tdci) > Musings on low power, high air temp. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20115 |
That does sound like a faulty VCV to be honest as that is what happens with that, at least mine did but never puts up a DTC as that isn’t part of the system.
Beyond that, an Intercooler upgrade especially if any tune is present. Fresh coolant also can knock a few Degrees off coolant and engine temps. You really shouldn’t be losing power in 6th unless heavily laden or towing heavy, regardless of ambient temp. Turbo actuator light lube, keeping clean MAF and MAP sensors and clean filters, fuel, oil etc all are good but a failing or aged VCV knock’s off top end power for sure. I also just run regular diesel, but wherever possible I always run Millers Diesel additive and have now for about 60k miles. This is just what I do, but I think it keeps the turbo cleaner internally and the injectors. Does anything here seem to ring any bells that might be any use? I’ve tried an aftermarket supposedly “OEM” air filter before too, and when swapped back to Genuine could find how restrictive that was. That’s why I stick to Genuine service parts, not cheap but you can get problems from other parts which is defeating the point of servicing anyway. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
16th Aug 2024 6:46pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3161 |
Are you sure it’s overheating due to ambient temperature? I wonder if you are cruising in a too a high gear and labouring the engine. At what revs do you cruise and when do you change up? Also do you have an OBD gauge to accurately live monitor temps, revs etc? WARNING. This post may contain sarcasm. |
16th Aug 2024 7:21pm |
I wish I had electronic OBD readings of engine temp when I changed the coolant on mine, but based on the dash gauge the needle dropped ever so slightly after changing it.
It would have been nice to see the actual readings. I think in hotter countries with regular high temps upgrades are a really good idea. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
16th Aug 2024 7:43pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4152 |
It's definitely not the VCV, the one in it is practically brand new and have had this issue with previous VCVs too. I already use the Millers stuff and I don't use supermarket diesel. I have a Nugget airbox and intake, bit again the issue was present before I had that. 2007 110 TDCi Station Wagon XS |
16th Aug 2024 7:54pm |
No live data, although I think my Nanocom can do it. The issue occurs when cruising at 60-65 in sixth, long inclines, high ambient temps. No towing, but quite heavily loaded. It has never occured in the UK for me. 2007 110 TDCi Station Wagon XS |
16th Aug 2024 9:03pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 756 |
Have you got the ‘upgrade’ thermostat for hot countries? I believe it opens 10 degrees sooner iirc. 2008 2.4 110 Utility Station Wagon XS.
16th Aug 2024 9:11pm |
Can you externally tell which is which with the thermostats in situ? NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
16th Aug 2024 9:15pm |
What are the revs in those conditions? I’d have to go for a drive to check but pretty sure I would be in 5th not 6th. You are asking quite a lot from the engine and need to be in the power band. Plus cruising under 70 mph in 6th isn’t great for the gearbox. If the nanocom can do it you should definitely record live values while driving, it should help you get to the bottom of it. WARNING. This post may contain sarcasm. |
16th Aug 2024 9:54pm |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 187 |
Can I ask - why is it bad to go into 6th under 70mph? I change up at about 56 - should I change my ways? Thanks (Maybe I have misunderstood).
16th Aug 2024 10:31pm |
So at 100km/h on the sat nav (62 mph) it's pulling about 2100rpm which is just about peak torque I think.
I assume standard thermostat, I've never changed it. 2007 110 TDCi Station Wagon XS |
17th Aug 2024 9:32am |
It’s not so much when changing up, although I depending on my mood I prefer to change gear between 2800 and 3200, but with my setup at least I feel it’s more mechanically sympathetic to cruise for longer periods in 6th at 70 mph plus. Under 70 I generally use 5th. Labouring in 6th can also cause mainshaft wear. Obviously there will be rpm/speed differences depending on your ecu map, wheel size, transfer box ratio you are running and whether loaded, terrain etc but generally you can feel when the truck is running comfortably and when it is being stressed. WARNING. This post may contain sarcasm. |
17th Aug 2024 11:02am |
Duplicate post. WARNING.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 409 |
May be of interest or help..
Here's a photo of my trucks gear train ratios.. I think I was just checking my speedo against the calculated speed in the case shown ..ie at 2000rpm.. With my set up and tyres I'd be doing 58/59mph at 2000rpm which is pretty well what my speedo is recording.. Click image to enlarge |
17th Aug 2024 12:51pm |
revd Member Since: 20 Apr 2024 Location: England Posts: 65 |
100 km/h up a long incline on a hot day in 6th - you're labouring the engine - you need to increase the boost from the turbo by increasing the revs - so either speed up before the steep gradient or change down sooner
17th Aug 2024 12:59pm |
