Home > Puma (Tdci) > Warning light
Ducko888
United Kingdom 2014 Defender 110 Puma 2.2 CSW Alaska White
Warning light
Anyone know what this yellow light means
Post #1042445 10th Aug 2024 8:08pm
Was there supposed to be a picture? Darren
Post #1042448 10th Aug 2024 9:02pm
Ducko888
Sorry added it twice but it didn’t come up
Post #1042467 11th Aug 2024 7:06am
Retroanaconda
Your manual will tell you that is a DPF warning light.
Post #1042468 11th Aug 2024 7:08am
Ducko888
Thanks yes i thought it might be. Im away from home thats why i couldn’t look it up. Appreciate your help.
Post #1042476 11th Aug 2024 9:41am
Ianh
You need to go for a 30 -60 minute high speed journey ( constant 60 plus MPH) to get the exhaust hot enough to go through an active regeneration. Don’t delay as if that turns to a Red DPF light you will need a forced static regen via diagnostics tools.
One thing to note, if this has not been caused by lots of short slow speed journeys you need to ensure the DPF pressure sensor, its wiring and the pipes to the DPF are all ok. Also that glow plugs and EGR are showing no DTC’s as they play a role in the DPF regeneration process.
Post #1042485 11th Aug 2024 11:54am
OP’s photo for reference:
Hope that is helpful. $W33T $0U7H3RN $UG4R
Post #1042500 11th Aug 2024 3:12pm
