Home > Technical > Iron Man Nitro Cell Suspension Upgrade
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
Hi Guys,
Ive recently fitted the Iron Man Nitro Cell coil springs and shock absrbers. Ive done approximately 5000km on them and have started to hear a jingle noise almost like im dragging chains on the road at speeds of over 100km/h. Ive had a look under the vehicle but couldnt see anything out of place or loose. My transfer box and clutch have already been replaced with new units so that cant be the problem. What I did notice is the front and rear drive shaft dont line up at the universal joints due to the gain in ride height after fitting the Iron Man suspension. Does anybody else have this issue after installing after market suspension? I will fit the standard coil springs and to see if the noise goes away. Land Rover's don't leak oil, they simply mark their territory!
Post #7314 15th Feb 2009 9:06pm
fekete
Hi shorty,
I think simonpuma90 had issues when he changed his set up two a 2in lift and had to
change his props and drive shafts Thumbs Up
In pumatdci threads look at simonpuma90 any lifted pumas second page NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #7318 15th Feb 2009 9:46pm
Arthur90
Does not fit with the speed that you quote but I have had problems with pea shingle getting into the centre of the front discs and making a jingle as it rattles on the vanes of the vented disc.
Post #7511 18th Feb 2009 8:59pm
jst
prop UJ? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #8035 4th Mar 2009 10:10pm
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
DC prop will do the job but you will need a td5 transfere box flange to give Jake a call at Devon 4x4 Thumbs Up
Post #8040 4th Mar 2009 11:18pm
jst
in my experience unless you fit castor corrected arms (which lower the diff nose) you dont need DC props on anything upto and including 2" lift. over 2" lift then yes. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #8063 5th Mar 2009 10:09am
simonpuma90
until you lift a puma, the engine is sitting on an angle to clear the axle which causes the output shaft on the transfere boxto be pointing up and then puts more angle on the prop Wink
Post #8065 5th Mar 2009 10:23am
jst
i stand corrected, that well thought out then! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #8066 5th Mar 2009 10:34am
