![]() | Home > Tdi > 300TDi / R380 ringing noise when changing gear |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3506 ![]() ![]() ![]() |
1. Does it still make the noise if you press the clutch and release with gbox in neutral?
2. Does it still make the noise if you press the clutch and release with gbox in a gear and transfer box in neutral 3. Is there a difference in test 2 if you select different gears? 4. Does it still make the noise if you press the clutch and release with drive in low range? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 144 ![]() ![]() ![]() |
Nothing sinister, a failed hooke joint at front of transfer box.
Thank you for the suggestions. |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
I was taught to always suspect a universal joint when you hear that sound.
