Home > Td5 > TD5 Fuel Gauge Not Working
Dandyservices
United Kingdom 2000 Defender 110 2.5 TD DCPU Alveston Red
Hi, I have a 2000 td5, the fuel gauge isn't working. Have had the fuel pump out and tested the sender with the multimeter which is all working ok.
I am thinking my next move is to test the gauge itself (all other gauges on the dashboard are working) but I am new to TD5 so just wanted to put the feelers out to see if there were any obvious things I am missing, read somewhere about it being linked to the speedo? Thanks in advance.
Post #1042342 9th Aug 2024 6:05pm
lightning
TD5 fuel gauges are quite cheap. You could buy one from Ebay and try it. lf it doesn't work, you can sell it on.
And it won't be a complete waste of time, at least them you'll know what it isn't.
Post #1047015 27th Sep 2024 6:41pm
Dandyservices
Thanks, it was the wire through the chassis rail in the end. So clipped a new one to the rail and problem sorted.
Post #1047877 6th Oct 2024 12:51pm
