Home > For Sale & Wanted > [For Sale] 2008 Defender 110 2.4 TDCi USW XS.
BrickBox
Evening all,
Me again Rolling Eyes
After finally making a decisive decision to sell the Defender. Here goes..
.HPI Clear
.February 2008 ‘57’ registration.
.Zermatt Silver - Code 798
.Non-Sunroof.
.No chequered Plate.
.118,500 miles
.Just 1 previous owner
.Full original booklets. 2 keys and all service booklets and guides.
.M1 DVLA class
.Utility Station Wagon from factory with original purchase documentation.
.XS Spec (A/C, heated windscreen, central locking, half leathers and leather steering wheel, full carpets, electric windows)
.Full documented service history.
Engine: 118,500 miles
Completely standard engine. EGR valve still in place and working as should be. New water pump, auxiliary idlers, tensioners and genuine aux belt. New battery, starter motor and recent injector seals and clamps done including the full rocker covers seals. Complete rocker seal kit bought from Empire tuning. Recent Fuel filter, oil and filter and also air filter. It had a new sump pan and gasket by the previous owner. So all gaskets have been replaced - so there are no oil leaks on this, which is definitely rare for a Puma.
Exhaust is original and getting scabby. It has been on my list to change, but there’s so much choice out there that I haven’t got around to buying one.
19.08.24 - New Genuine LR intercooler and genuine boost pipes, a/c regas and fresh coolant change.
Suspension and steering
Standard shocks and springs with slight corrosion on the springs. This is just the paint is starting to flake off the coil springs. Twisted do have a complete set of delivery miles genuine springs for a 110 USW for £145 for the set. I can buy those to go with the vehicle if need be. New genuine steering damper, drop arm and track rod bar with all new drop links. Swivels are greased and not pitting.
Driveline:
Rear genuine HD LR single piece drive shaft upgrade. These were bought from Twisted off a vehicle they were rebuilding for a conversion. New genuine front prop. Both front & rear props recently re-greased.
LOF single piece output shaft & LOF Roadspec clutch kit with 2.2 TDCi upgraded slave cylinder. New clutch switch, oil etc. The clutch and output shaft was only fitted last month at a cost of just under £2,000 at Promec LR Specialist. and is still under warranty for 11 months as it was fitted at a LOF approved LR specialist. The driveline is unbelievably tight with the rear shafts and output shaft upgrade.
Low range gears work and select perfect and dash light illuminates. I make sure I use it just to stop any selectors going stiff. I’ve never taken the vehicle off road.
Chassis:
Original fantastic condition chassis with numbers all present. This chassis is not waxoiled or anything.
VIN numbers all match on the chassis, windscreen plaque and log book. No welding or anything of a kind. It’s had ACF-50 sprayed a couple of times a year and I feel that’s been enough to look after the chassis for what the vehicle gets used for (some school runs and weekend spin for coffee)
Interior:
All standard and original XS Spec half leather interior. Full carpets and genuine rubber mats throughout.
Only change I have made inside is adding a genuine LR Cargo/Dog divider.
19.08.24 - Genuine wiper motor, spindles and relay. (Another big expense job done)
Exterior:
All standard fittings inc the XS sidesteps. Only modification is the KBX front grill, wing vents and clear light lenses front, side indicators and rear lights. Standard fitment Continental Crosscontact 235/85-16 tyres. Heavy duty tow bar and electrics, all working as expected - trailer light flashes on the dashboard when plugged in.
Bodywork does have some marks, small scratches and dents reflected in its age - but nothing had been hidden. It’s a true, genuine vehicle.
As you can see, this has been absolutely pampered by myself and the 1 previous owner. It’s had an easy life and the condition reflects that. All the expensive jobs have been done and the ‘prone’ failure point of a Puma output shaft will never be a worry for the next owner, with the LOF single piece expensive upgrade already taken care of professionally. This Defender is ready for the next owner to take it on a reliable overland adventure or carry on living a pampered life.
Only reason for sale is an expanding family and wanting 7 seats.
I think this is very reasonably priced given the maintenance and condition.
£19,995 ono. NO VAT.
Located South Wales - SA9
I will add more pictures in the week.
Cheers Smile 2008 2.4 110 Utility Station Wagon XS.
Post #1040536 20th Jul 2024 9:50pm
mini Anaconda
Looks great and well maintained. Nice to see a completely standard example. Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #1040539 20th Jul 2024 9:58pm
Welshsurferdude
Wales
Might be a tip to change the KBX front end to something else and change the wheels to black sawtooth, might make it more sellable to the general market, make it stand out a bit from the other normal ones. Thumbs Up 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #1040557 21st Jul 2024 6:58am
BrickBox
I am considering putting the original grill back on and standard wing vents. Take it back to completely OEM. 2008 2.4 110 Utility Station Wagon XS.
Post #1040559 21st Jul 2024 7:04am
BrickBox
Post #1040701 22nd Jul 2024 11:36am
BrickBox
Taken today. 22.07.2024
Car has not been washed this weekend, so excuse a little dirt.
Post #1040732 22nd Jul 2024 6:42pm
BrickBox
Spare key and all original booklets. 2 service books. Original service book full, 2nd book from 2022 onwards.
Post #1040871 24th Jul 2024 9:27am
jst
thats very clean for the age and mileage Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #1040925 24th Jul 2024 8:32pm
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
Great looking defender! In very good condition too Cool
Im back in the market for 110 now but need to shift my RR Sport first.
Will be keep an eye on the thread Smile
Post #1041924 5th Aug 2024 10:46am
BrickBox
Thanks both, much appreciated Smile 2008 2.4 110 Utility Station Wagon XS.
Post #1042049 6th Aug 2024 9:49am
karlp606
Anymore interior pics Brickbox?
Post #1042252 8th Aug 2024 5:09pm
BrickBox
Post #1042255 8th Aug 2024 6:00pm
karlp606
Thank you Thumbs Up Cool - is the boot area carpeted or rubber matt also?
Post #1042294 9th Aug 2024 9:53am
BrickBox
I will take a picture of the boot area over the weekend.
It’s fully carpeted, with a genuine rubber mat. And then the genuine full cargo barrier/dog divide. 2008 2.4 110 Utility Station Wagon XS.
Post #1042304 9th Aug 2024 11:40am
BrickBox
Just had this back from my Specialist. Wipers started playing up, so I’ve had a new genuine LR wiper motor, cable and spindles fitted at quite a cost Shocked but they are now better than ever!
While it was at the garage I’ve had a new genuine intercooler and boost pipes fitted , as the standard ones were looking a bit brittle. 2008 2.4 110 Utility Station Wagon XS.
Post #1043202 19th Aug 2024 4:22pm
