Home > Technical > Front Hub Leaking Grease
BenUK1978
United States 1993 Defender 110 200 Tdi SW Fuji White
Hello - the front passenger side hub on my 1993 110 has started leaking grease. Please see attached. Only just noticed it. The swivel housings were replaced a few months ago. Wondered if anyone could give me guidance on a possible cause / urgency for repair. Thank you.
Post #1040350 19th Jul 2024 2:50pm
MattBee
Possibly a blocked axle/diff breather. That’s what caused a similar issue for me. Assume it’s to do with different pressures inside and outside causing blow by.
Post #1040358 19th Jul 2024 4:21pm
BenUK1978
Thank you. Thinking about it, i only noticed it after doing some fairly rough and wet trails in her.
Post #1040359 19th Jul 2024 4:25pm
landy andy
Check wheel bearings don’t have any play and are overheating the grease.
Post #1040362 19th Jul 2024 4:59pm
BenUK1978
Thank you. I will try that. If it is a blocked breather, how does one unblock / clean it?
Post #1040363 19th Jul 2024 5:03pm
Retroanaconda
You’re missing the hub cap, which is why it’s leaked out.
Get genuine replacements, the aftermarket ones are terrible.
Post #1040366 19th Jul 2024 6:13pm
BenUK1978
i do actually have the plastic hub cap, just removed it for the photo. The grease makes it way past the hub cap which i don't think is normal.
Post #1040367 19th Jul 2024 6:20pm
Retroanaconda
Then it needs replacement, it should be a fairly tight fit and a good seal.
Post #1040369 19th Jul 2024 6:46pm
Mo Murphy
Get a genuine cap, they are more expensive but they don't leak.
50 Shades of Pennine Grey
Post #1040370 19th Jul 2024 6:52pm
