Home > Faults & Fixes (L663) > flat battery and CTEK charger |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 751 |
What do you mean flashing? Flashing an error or something else? My charger flashes the green full charge light when the battery is fully charged and cycling.
14th Jul 2024 9:14pm |
johncorrisgrey Member Since: 17 Apr 2023 Location: south yorkshire Posts: 11 |
no amber lights on the scale showed at all, then the green light started to flash. Never seen that before, would have expected it to go at least to some kind of charge.
John |
14th Jul 2024 9:23pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
Very few intelligent chargers will charge a totally flat battery, but if you can get some.charge in with a dumb charger then the ctek should be fine. It's just a characteristic of this type of charger, it has to be able to recognise that it is connected to a battery.
14th Jul 2024 11:23pm |
julian Member Since: 17 Feb 2017 Location: Devon Posts: 122 |
As mentioned, they won't charge an under voltage battery. You can trick them by connecting them up to a good battery, getting them charging it, and connecting your dead battery with jump leads (in parallel) and then, after a few mins, removing the good battery, without pressing any buttons on the charger. |
14th Jul 2024 11:40pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 820 |
I just returned from a 8 week break in Europe and had to recharge the battery,
our CTEK M7.0 fully charged it over 8 hours.. used it a few times without any hassle yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
15th Jul 2024 1:23am |
We will have to wait for the op to confirm. But it doesn’t sound like a completely flat battery in their op. |
15th Jul 2024 6:21am |
thanks for your suggestions,
battery was at least 70% land rover assist guy got it started and we let it tick over for at least 1 hour, in that time battery state went up from 20% to 70. when he left I put the CTEK on to leave it over night but then saw the symptoms as described, panicked and disconnected straight away May try it again later today, going out for 25mile round trip, if starts? Just been browsing and looking at NOCO lithium charger/starter,(model to do D300 about £109) we are on the continent for 5 weeks from end of July and will be most miffed if it continues to play up. Waiting for dealer to get back to see if they can fit me in for a check up. John |
15th Jul 2024 11:26am |
mlambton Member Since: 20 Apr 2024 Location: Devon Posts: 22 |
Those NOCO jump packs are excellent. Ive had one for a couple of years and its helped me and my neighbours out so many times. 2024 L663 110 Defender P400e Carpathian Grey
2015 Range Rover L405 SDV8 AB Corris grey 2010 Range Rover TDV6 HSE Narra Bronze sold 2006 Discovery 3 SE green sold Defender 90 td5 sold Defender 90 soft top sold |
15th Jul 2024 11:42am |
JonathanP Member Since: 01 Jun 2024 Location: Barnard Castle Posts: 22 |
If you are charging using the jump start connectors under the bonnet just jiggle the crocodile clips a bit to make sure they are in full contact with the two posts especially the red one (positive) in the plastic box it makes a better contact. The plastic box makes it a little bit more difficult to get a good connection depending on the angle.
23rd Jul 2024 9:54am |
well flat battery again today think its a separate issue with tow bar not deploying, gonna put a post on for that, contacted original dealer and heard nothing back from them!!! so going into dealership Ive used for years previously. Eventually settled for a RING lithium power pack and separate battery charger only because they have 10% off direct from them, free post and 2 year warranty.
John |
23rd Jul 2024 7:10pm |
