![]() | Home > Puma (Tdci) > Vacuum pump |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 647 ![]() ![]() |
Can anyone tell me what the blanked off pipe on the vacuum pump is for.. Something I don't have fitted or a test point???
It's the 2.2 tdci with the pump mounted on the rear of the head.. Ta๐ ![]() Click image to enlarge |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
last post at https://www.defender2.net/forum/post915869.html Puma 110" SW
Ahh.. Thanks..
It appears that's it's not a connection that is used as standard on the defender then.. ๐ |
๐คฃ
I won't need that.. My water just runs out through the holes in the floor๐๐ฉ |
