Home > Puma (Tdci) > Intercooler upgrade
lakes
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Intercooler upgrade
I posted this time last year asking for advice on why my 2.4 was going into limp mode when going 70+, on a hot day and with the AC on.
Turns out it’s the Intercooler - it’s not big enough to deal with all the heat in the conditions listed above.
Maybe a stupid question but I’m going to go for an Alive ultimate Intercooler and get the silicone hoses. Does getting a bigger Intercooler make the engine take longer to heat up in winter or any other ‘negative’ effects?
Post #1038144 22nd Jun 2024 5:30pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
No negative effects, whatsoever! Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1038146 22nd Jun 2024 5:41pm
MK
I do not think it is an intercooler problem, but rather the cooling system. It is known issue. Puma 110" SW
Post #1038157 22nd Jun 2024 8:44pm
Welshsurferdude
Wales
Upgrade the radiator too Thumbs Up
provided that everything else is working as it should 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #1038163 22nd Jun 2024 9:09pm
jst
2.4 doing 70mph on a hot day with ac on, limp mod shouldn't be anywhere on the agenda assuming everything is working as it should be.
As above I would start with cooling system. Pipework, water pump, correct level, correct flow, good rad.
Ambient temperature doesn't make much odds to intake temp in the scheme of things. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1038185 23rd Jun 2024 8:58am
Chicken Drumstick
Re: Intercooler upgrade
How do you conclude that the standard intercooler is too small for doing a standard thing such as running at motorway speeds? Do you not think the factory and the thousands of people who bought these might have done this sort of thing?
Upgraded intercooler will be an improvement in performance even without a remap. But I doubt it’ll fix the fault you are experiencing. I would focus on repair rather than modifying at this stage.
Post #1038204 23rd Jun 2024 1:23pm
andy63
I may be missunderstanding but the ambient temp will determine the intake temp.. With the best intercooler in the world and travelling at a good speed the intercooler can't do better than ambient temp for the engine intake temp👍..
I have seen my ambient and intake temp the same but there is usually about a degree or so between them.. But that's popping along and it's a bas upgraded intercooler..
Post #1038213 23rd Jun 2024 3:08pm
lakes
I was advised it was the Intercooler by my independent last year when the problem started - they also mapped it but it’s smoked ever since and I’m not really happy with it.
It’s only done it 3 times, always on a really hot day.
Anyways, I’m making the pilgrimage to Alive to have them give it a once over, smoke test and hopefully Intercooler, hoses and new map done.
Post #1038400 25th Jun 2024 6:40pm
jst
thats your problem then. mapped for too much fuel hence the smoke and making it run hot. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1038401 25th Jun 2024 6:54pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Maybe best to get an Alive map while you are there…
Post #1038402 25th Jun 2024 6:57pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
My first thought too, also I’m very surprised the indie remapped it knowing there was an issue with the intercooler.
I’m sure Alive will get to the bottom of it though. Let us know how you get on. WARNING.
This post may contain sarcasm.
Post #1038404 25th Jun 2024 7:02pm
Notyalc
There may not be a problem with the intercooler…
Post #1038411 25th Jun 2024 8:34pm
MK
agree.
The overheating issue also depends how you drive regarding the gas pedal position vs RPMs (as a function of gear selection and speed). Puma 110" SW
Post #1038424 25th Jun 2024 11:30pm
Chicken Drumstick
Ok some critical info left out of your opening post. Remapping on a stock intercooler is not really advised IMO. It is the wrong mod to do first. Certainly if it is now smoking and causing over heating, your EGT’s must be through the roof.
Based on this and fact they applied such a map to a stock vehicle I’d also want to question the quality of the map. There are lots of very poor maps around that seem to get shared online and reused by people with too little knowledge to know what they are doing.
Options you have are:
-return to a standard map. This will likely fix the problem.
-add a big intercooler. This “may” fix the problem. But might not. Also do note that not all aftermarket intercoolers are equal. Which means the map may be intended for a specific grade of intercooler.
-fix a big intercooler and get a custom remap. For me this would seem the best solution and given that the cost of a custom map is not all that much. You should end up with a vehicle that runs way better and hassle free and without the smoke.
Post #1038436 26th Jun 2024 8:13am
jst
I suggest you find anther garage to do the work for you other than your current independent.
Unless of course they mapped it and said you need a larger intercooler to go with this map, it won't worked well otherwise, and you declined?
Betting is your intercooler is fine and work wonderfully with a standard map.
Best to get a map that's been developed and tested for the application you require for the hardware you have. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1038443 26th Jun 2024 9:32am
