![]() | Home > Modifications & Maintenance (L663) > L663 remote activations, possible? |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 308 ![]() ![]() |
Hello, does anyone have any reference to this then?
Huwrhys Member Since: 27 Mar 2024 Location: Hornchurch Posts: 134 ![]() ![]() |
I'm not aware of it being something that can be carried out remotely. Normally you'd need a Gap IID G4 tool to effect the changes to the CCF (Car Configuration File) to enable the adaptive cruise and other changes. I know Hunters Prestige do activations via a laptop so assume they use a different tool/software to achieve the same end.
I would be wary of paying someone to do something remotely as they'll expect payment up front and what do you do if they don't effect any changes? My advice is get a Gap IID G4 tool and recoup the cost after two activations. I'm not sure where you stand regarding warranty. 24MY D300 130 X-Dynamic HSE Santorini Black |
Thanks for the answer, my interest is only and exclusively in the adaptive cruise control, which is relatively cheap to activate, but I think that your advice regarding the purchase of the GAP IID is wise advice...but I don't know why it gives me afraid to use it! maybe it's because Spanish was never implemented in the tool and my English is limited and I could screw up a lot... I don't know. ..I'll think about it, thank you.
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 38 ![]() ![]() |
Hi Ruben,
I did some change by myself with GAP tool, and no issues with dealer. But, I also expererimented an issue where dealer change a module and reload factory CCF file, so all changes made by myself was lose. Not a big deal, just need to redo changes with GAP tool. Regarding companies doing changes in remote, I have some experience, sent me a PM and I could share witch company I used. Regards |
Before you make any changes with the tool it takes a backup copy of your files first. If you make a mistake you can revert to the previous settings. 24MY D300 130 X-Dynamic HSE Santorini Black
In reality it would only be to activate the Apatative Cruise, I don't know how complicated it can be to do that by myself, the modification of the CCF I imagine is indirect, I won't have to edit it and I won't have to put my dirty hands in there, or even see it, no ? I imagine I would sell the tool immediately afterwards.
Iβll give you Β£50 for it! 24MY D300 130 X-Dynamic HSE Santorini Black
You are very generous, I was thinking of asking for Β£25!! π
β¦. But seriously, with the GAP is it necessary to physically edit the CCF? I thought that you only chose the modification and the machine did it for you, if I have to see, edit and modify the CCF, you make me even more discouraged from doing anything with such a risk!! |
Read through the Gap IID thread on this site and it talks you through quite clearly what it is you have to do. ππ» 24MY D300 130 X-Dynamic HSE Santorini Black
ππΌππΌππΌ
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 272 ![]() ![]() |
There is a company that sends you an adapter, you need a windows laptop and they remotely log into your car and can do changes, I think its VulKan UK 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Theyβve rebranded themselves. They are now called Hunters prestige. 24MY D300 130 X-Dynamic HSE Santorini Black
you are right, just. had a brain freeze. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
