Home > Technical > 200tdi running on 2 cylinders.
SADS
United Kingdom 1990 Defender 90 200 Tdi SW Arles Blue
Evening everyone.
I'm looking for some help please.
I have a 1990 200tdi 90 (discovery 200tdi engine). Back in January I broke down on the back 45 mins of a 3 hours journey on the A14. the engine lost all power and there was some smoke coming from the air filter. On inspection I saw there was some oil in the air filter pipe that must have been coming out of the manifold? The engine was very low on oil. It's since had a full oil change.
Anyway it's been at a LR specialist since January. They initially assumed the engine was knackered at the bottom end. However, once they actually looked at it, they have said it's just running on 2 cylinders, and would need to take the head off to find out why. It's running very rough as you can imagine.
Since they said that taking the head off to look for issues could get expensive, I thought I would revert to this forum to ask what people think this could be before I start spending money. Could anyone point out anything they have had before?
I actually need to sell the vehicle to recoup some money. I need to know if it's worth spending the money to sell the vehicle working or sell as a spares and repairs vehicle.
Post #1037249 12th Jun 2024 8:08pm
sasdiscos
200 to is very solid.
1st should be compression test.
2nd check turbo for oil passing if you had oil in the manifold.
3rd would be injectors.
And then test the injection pump.
Steve.
Post #1037250 12th Jun 2024 8:16pm
SADS
Injector pump only went on brand new in November 2023 so that should be ok.
Do you know roughly what kind of cost would be associated with these?
Post #1037251 12th Jun 2024 8:20pm
sasdiscos
Compression tester is 30 quid of eBay.
Pump can be tested by disconnecting and fitting hoses and then putting into bottles. Turn over and measure.
Injectors may need to be sent away for testing.
When I did mine I think I just moved the pipes and put them into bottles as well.
This was when I flooded the fuel tank in sandy water.
There really can’t be that much wrong. It’s a very simple set up.
Steve.
Post #1037253 12th Jun 2024 8:33pm
SADS
Thanks sasdiscos.
It's still at the LR specialist which is 150 miles from me. I will need to call them and speak to them tomorrow.
Just a thought and some context. I got this vehicle in may 2023, haven't had it serviced yet. I trust that the last owner did service it like they said they did. But if not, could it be a knackered fuel filter potentially that's the cause?
Post #1037260 12th Jun 2024 10:02pm
Retroanaconda
Could also be something simple like a snapped rocker shaft etc.
Post #1037267 13th Jun 2024 6:06am
landy andy
The basics need to be looked at first.
Are you getting diesel to all the injectors, are you getting similar compression on all cylinders, are all the valves moving, and at the correct time.
To see if you are getting fuel it’s just a case of cracking the injector feed pipes. Then a test with compression tester. If low the apply an air supply to cylinder and find where your air is going. To do this you need both the valves shut, so will be taking the rocker cover off and you can then see what your valves are doing, and you can check timing.
Your problem could be as simple as bent push rods. Nice simple and cheap. But also something I’d expect the garage to have checked.
Post #1037270 13th Jun 2024 7:04am
sasdiscos
It could be but wouldn’t explain why it’s only firing on 2 cylinders.
I’d ask them if they have checked the injectors and the pump? And then ask why they think you have damaged pistons.
As said, for them to take the rocker cover off to check the rockers is no drama.
I suppose the only other think is that you have damaged valves. But this would show up on a compression test.
Steve.
Post #1037271 13th Jun 2024 7:05am
landy andy
A compression test wouldn’t show up bent valve push rods though.
Post #1037272 13th Jun 2024 7:07am
spudfan
Ireland
If a timing belt was fitted recently and not fitted correctly it will snap or slip causing internal problems. Get them to have a look at the timing belt. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1037472 14th Jun 2024 4:45pm
