Home > Puma (Tdci) > Solenoid or starter motor? Non-starting issue. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
I suggest to check (-) points to chassis and transfer case. Puma 110" SW
8th Jun 2024 3:32pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 838 |
Get a long bar and put it on the starter motor body and give it a tap. See if it starts then. Could be a jammed gear. 2008 2.4 110 Utility Station Wagon XS.
8th Jun 2024 5:06pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
Worth checking for parasitic current draw as well, and that can be something from a relay coil constantly energised or water where it shouldnโt be.
The latter here I found water in a few years ago, will cause a monitor current draw, but enough to bring the battery down to low voltage. Beyond that, maybe a loose ground or battery clamp in particular the main ground the transmission. A Multimeter maybe useful here. Good luck. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
8th Jun 2024 5:53pm |
Millerdark Member Since: 16 Sep 2015 Location: Berkshire Posts: 25 |
There is a post on how to troubleshoot a drain to earth. https://www.defender2.net/forum/post969511...2C%20there's%20a%20problem.
9th Jun 2024 5:27pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 498 |
How old is your battery ? Try jump start from another vehicle |
13th Jun 2024 6:46pm |
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 |
Click image to enlarge Finally sorted after needing recovery. It was the starter motor which has been replaced. (Photo shows the Land Rover in its natural environment). |
20th Jun 2024 10:47am |
Thatโs unfortunate, but at least you know what it is and that it is now solved.
20th Jun 2024 11:22am |
