![]() | Home > In Car Electronics (L663) > Low Profile Shark Fin Delete |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 45 ![]() ![]() |
Add a roof rack and you'll quickly find out that shark fin is the lowest thing on the roof!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
Won’t be long before people will be retrofitting an antenna / aerial in the classic location instead.
Where it’s not in the way, rather than causing the issues y’all talking about right there with the roof clearance. ![]() Good ol’ LR fix some issues, create some new ones, and repeat some existing ones. It’s progress, or is it. ![]() ⛽️🛢️⚙️🧰💪 |
TSY Member Since: 27 Feb 2024 Location: Colorado Posts: 11 ![]() ![]() |
Very true! I've been checking out some low(er) profile options that stop just short of the sunroof. (there are only a couple of ways to do this). Looking for a place to stash fuel & water bladders and avoid adding side panels to the rear 3/4 glass. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
The shark fin has the camera for some...they used to do (on other models) different types ive not seen them doing this for a while
Worse is the double shark fin! Mike |
