Home > Puma (Tdci) > Puma buying advice |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
I'm going to look at a 2015 2.2 with 113k miles on the clock, can anyone tell me if I'm going to regret it? And what to look out for please? 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
2nd Jun 2024 8:52pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3418 |
As above plus a 2.2 is just like any other Defender. Personally I think rust and corrosion could be the biggest issue on a Defender, although being a 2015 should not be too bad. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
3rd Jun 2024 6:05am |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
Have a good look at the windscreen frame for corrosion.
3rd Jun 2024 7:44am |
Thanks all, I'm fairly happy with all aspects bar the 2.2 engine and perhaps the MT82.
Re the DSC - what exactly is the function and how could it be tested? It appears to have been serviced every 12k miles by JLR, is that the normal interval? Seems high? Anything else to be aware of / look for? I have heard of some failures such as over fuelling, holed pistons etc. but can't recall if that was for the 2.4 or the 2.2. What about timing chains? 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
3rd Jun 2024 3:04pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 578 |
Check if oil pump has been replaced at all. Then factor in cost of replacement on purchase for piece of mind. Some say the later oil pumps were ok but ask any cautious transit guys and they will replace every 50k at the most.
3rd Jun 2024 7:41pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 381 |
Hi . If helpful..... I have had my 2015 Puma since new and its covered 95k now. Oil change every 6k and the only engine fault I have had so far is a faulty EGR valve at around 30k. I replaced this but is a long fiddly job. I drive 14k a year and is a daily driver. No issues with DPF lights. I have no oil leaks (yet!) from the engine, gearbox or axles. if you can find a well maintained engine it is likely to help. But good chassis and bodywork is worth the inspection too. 2015 90 XS Santorini Black
5th Jun 2024 3:38pm |
