Home > V8 > 3.9l V8 serpentine engine failing emissions
falkster
Germany 1988 Defender 110 V8 Petrol CSW Trident Green
Hi, I am in the process of buying a 1988 Land Rover 110 that had an engine swap from its original 3.5l V8 to a serpentine belt 3.9l V8.
The guy selling it kindly offered to renew the MoT before handing over the vehicle. Now it appears to fail the emissions test on the original test due to an unstable idle speed and on the re-test with corrected idle, it failed again...
I am sitting remotely on this so can't look at the vehicle, but the question I have, is this a common thing? and if anyone else had similar issues, how did you solve it?
Is the only way to have a tester who happily raises the idle speed slightly to get results??
I am keen to get the vehicle rather sooner than later, so just trying to figure if I can siomehow draw from the collective knowledge.
Thanks for your help. Thumbs Up
Post #1036289 2nd Jun 2024 8:42am
Chugga90
Previously had an 85 c plate 90 with 3.9 v8 from a classic Range Rover fitted.
That had idle issues and from memory it was a stepper motor on the inlet pipe or plenum chamber?
Might be useful 🤔
Post #1036319 2nd Jun 2024 3:15pm
sasdiscos
As mentioned stepper motor. Don’t buy cheap.
Also, lambda sensors worth a check.
Mine just failed and I needed a new lambda. I’m going to assume that the Brit part lambda sensors will be a yearly service item going forward. Lucas ones no longer available.
Steve.
Post #1036324 2nd Jun 2024 4:26pm
Linds Hanson
Probably worth disconnecting the stepper motor and setting the idle with the air screw for the MOT.
Post #1036399 3rd Jun 2024 5:23pm
sasdiscos
If you’re going to play around with the idle adjuster screw make sure you follow the lr technical booklet. They are set from the factory and should never need adjusting.
Post #1036426 3rd Jun 2024 9:32pm
TexasRover
Steve.
1988, did they have injection then? 3.5 came in carb version at least in 1984 (I had one). And swapping the block to a 3.9 should make no difference to the applicable emission requirements if 1988, which is not much of a requirement. Injection, cat etc was only introduced in Europe as a requirement to meeting emissions in 1992.
Sounds like the Carbs need a tune up, check ignition etc. Old school, its easy plenty of U-tube to guide you.
Post #1036436 4th Jun 2024 6:33am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Re: 3.9l V8 serpentine engine failing emissions
On my 3.9 serp an LR 'specialist' started replacing things and messing with the idle speed. It still was over on emissions. They had it for 3 months, wanted £1k (didn't pay that much, but it's another story) and didn't fix it.
V8s are prone to vacuum leaks - which messes with idle and rich fuelling. So with the gift of lock-down time I chased every vacuum line and hose. Many were iffy, and replaced to ensure reliability, but didn't fix the issue.
Turns out mine was letting in air through the inlet manifold valley gasket because the manifold wasn't tight. The lambda sensors were seeing lean mixture and enriching it. The mixture was fluctuating, causing hunting and fast idle because if the excess, non-metered air.
The symptoms you describe are similar. So I would suggest you have any vacuum leak checked methodically and eliminate that before starting to change parts. The sensors are pretty simple on the 14CUX and failed ones seem to be fairly rare.
Also check the dizzy cap - even OEM Lucas versions are rubbish these days, and can rotate on the distributor body causing all sorts of intermittent timing and ignition symptoms.
It has taken 2 years and about 10 attempts to get the base idle and mixture correct again. So mess around with it at your peril! JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #1036548 5th Jun 2024 10:05am
falkster
Thanks everyone for your valued input. Lambda sensor it was!
The vehicle now has passed the MoT and I'll pick it up in the coming days.
Time to start a new "My Defender" thread.
Again, thanks all! great forum... Smile
Post #1036680 6th Jun 2024 1:52pm
falkster
What a story! still using the V8 or did you have enough after that?
Might contact you on the fault finding route. I'm new to V8's and even though it seems to work now, I might give the vacuum hoses checking a go. Did you have diagram or anything that guided you where and what exactly to check?
Post #1036681 6th Jun 2024 1:59pm
Lodelaner
Still have it - it's my forever Ninety!
My first car was a RRC 35 years ago and I'm still learning about them. There are many vacuum hoses plugs and blanks on the manifold - so I simply checked each hose in turn by removing, squeezing to check for splits and cracks and refitted.
Glad you got it sorted - and thanks for sharing the solution! JB
Post #1036682 6th Jun 2024 2:09pm
