Home > Maintenance & Modifications > Wipac LED light conversion |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2079 |
You need a LED indicator relay https://boltonbits.co.uk/rdx-4-pin-flasher-relay.html
All will be revealed when you read the Product Description |
31st May 2024 7:19pm |
FireTom Member Since: 26 Nov 2023 Location: Poole Posts: 14 |
Thank you for that, I will get that if I need to but if I swap the relays over between the one with standard and the LED that should work shouldn’t it?
31st May 2024 9:31pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2174 |
yes if your old car worked fine then in theory that has had a different relay fitted so swapping to the new one will solve
BUT it may have had a wiring 'work-around' like adding an extra halogen bulb in-line if you never did the work originally |
1st Jun 2024 7:27am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5753 |
The relay swap should work ok, and you will see if you have a non standardised relay when you compare the two. Most of the led relays are adjustable so you may need to fiddle a little.
1st Jun 2024 9:32am |
Thanks for your help everyone. I’ll swap them over and go from there.
1st Jun 2024 4:58pm |
