Home > Wheels & Tyres > Tyre Pressure Advice
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Standard 2010MY 90 XS on factory fitted Boost alloys and factory fit tyres. The tyre pressures have been as standard 30psi Front 38psi Rear as detailed in the handbook. Tyre wear as measured today showed more wear in the centre of the tread compared to the outer and inner which were equal i.e.: High Pressure.
What pressures do you use? Question LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #100764 18th Nov 2011 6:02pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
28, 35 on 235's BM52
Post #100781 18th Nov 2011 6:58pm
BigMike
depends on what load you're carrying, how you drive, where you drive, it's not easy to answer really since handling is so hugely affected by it.
I ran my 90 at 32 front, 36 rear. no wear issues and great handling (on OME shocks and iron man B springs)
Post #100828 18th Nov 2011 10:18pm
WelshGas
Thanks BM52. That's what I've set them to now.
Big Mike - standard suspension, gentle greenlaning and mainly tarmac. Rarely carry enough in the back to require headlamps to be adjusted. LANDYWATCH
Post #100835 18th Nov 2011 10:47pm
