![]() | Home > Off Topic > Discovery 2 XYZ switch and no front electric windows. Help! |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 629 ![]() ![]() ![]() |
NO words of advice, but I can sympathise - our D2 has the flashing M&S lights with no apparent solution. We simply turn to off and back on again and it clears. Very frustrating! JB
@Lodelaner Instagram Youtube greenlaning and other LR related content |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1312 ![]() ![]() ![]() |
Picked up some ideas over the past day or so from Landy Forum.
It does sound like the BCU module could be failing, but before swapping over the BCU from the other Disco (which involves some re-coding using Nanocom), we are going to check the fuse box and relays feeding the BCU first. Won't be tinkering again until Wednesday next week, but fingers crossed!! |
Well after major surgery and a lot of head scratching, it turned out to be a faulty relay on the passenger compartment fuse box.
Moral of the story. Check the easy things first and don't take Nanocom at face value ![]() At least if the XYZ switch needs replacing in the future it will now be easy to get to ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
